Cooling Fan Option
Zepper
18,998
It should be somewhere in the vicinity of the hard drive bays. I haven't had hands-on with that specific case. Take off the front bezel and I'm sure you'll immediately see where to put it.
.bh.
yh125d
6,886
I don't think there's a front fan in that case, a 120 in the back and a 80 on the side door
Rockinacoustic
2,460
I have the same case, there is a front fan mount, but only 80mm located on the bottom HD rack. You'll need to take the front panel of the case off to install it.
You can also install an 80mm on the side panel, and even on the lower expansion card vents I've been pondering ways to add two 80mm fans. It's an easy case to mess around with :)
Boyo
1,406
Put in 2x 80mm intake fans. One on the side and one in the front of your HD bay.
