- Mar 25, 2011
- 52
- 0
- 0
Can anyone please tell me, what is the advantage of using 4 pin molex cable over a 3 pin cable for a cooling fan ?
The cooling fan speed is controlled according to the heat of the computer from the motherboard right ? The motherboard will only be able to control the cooling fan if the fan is connected to the motherboard isn't it?
I'm asking these questions because i need to buy a cooling fan with a 3 pin connecter but i searched on ebay and the one i want to buy has a 4 pin molex cable not a 3 pin? So i want to know if i connect the cooling fan directly to a molex cable from the PSU, the motherboard won't be able to control the speed of the fan right ?
