Cooling change for my Entho evolve ATX High Temps Under Load
Aug 18, 2012
12,698
I know my signature says the CPU is at 5ghz but this was when I first bought it a year ago. Last night I spent many hours trying to find my overclock again since I last tried overclocking.
I can't even seem to get it running at 4.7 on all cores. I followed a decent YouTube tutorial and it looks like this:
Multiplier 50 voltage 1.35 boots
Run prime 95 v26.6 a few min Blu screen
Temps up to 90c.
Multiplier 47 voltage 1.3 boots
Prime 95 for 5-10 min, blue screen
Temps mid 80-87
Multiplier 47 voltage 1.28
Prime 95 ran for a little over an hour no errors
Temps 83-85
Ran it again and after 15 min blue screen
Temps 83-85c.
Got tired of testing it and set it back to stock.
I'm using a Corsair h100i v2 AIO and I'm looking to find another better AIO that will fit the Entho evolve ATX case.
Is the Corsair 115 AIO better or should I look into something else? Or did I not luck out in the CPU lottery?
What are you guys using for cooling? I had a hyper 212 but it broke so that's why I got the AIO.
Mar 10, 2004
28,516
235
AVX offset?
Aug 18, 2012
12,698
I have MCE and CPU svid disabled. I believe it's level 6 I'm using for the CPU instructions. Cpu cache is set to 42.
Avx is set to 3.
Similar threads
ASK THE COMMUNITY
TRENDING THREADS
