- Aug 24, 2001
- 1,590
- 0
- 0
I've recently installed a Radeon 9800 Pro video card in my system and noticed that the case and CPU temps have rised a few degrees. The PSU fan is also spinning faster, wich has caused noise levels to go up.
I was thinking about getting an after market cooler for this baby. My two choices are:
Zalman VF700-AlCu
ATI Silencer 1 (Looks sooo much cooler).
So, which one do you think I should get?
EDIT: It seems that I don't have enough clearance to install Silencer 1, but I'll check it to make sure.
Af for the Zalman hetasink, can I plug the fan to my fan controller and run it at low speed during normal operation and switch to full (12v) speed while playing games?
Would you use Zalman's thermal paste or Artic Silver 5?
Zalman VF700-AlCu
