cooling an overclocked system
jswjimmy
892
i need 2 more case fans for my computer i was thinking of buying 2 Vantec Tornado fans one for case and one for cpu. i want to 80mm heatsink to and use the fan off of it for case. but can the tornado be hooked up to ps my mobo has only 2 fan power connectors. or should i buy one tornado for the cpu and a stealth for the case?
jswjimmy
892
i also need a 120mm for the front. is a enermax CS-3051L-S3A
SinfulWeeper
4,539
Might I enquire on why your wanting tornado's for? With just a few more dollars you can get a water cooling setup that can and most likely will cool more than what your wanting to do. Plus you do not get all the noise polution.
jswjimmy
892
where can i get a water cooling kit for under 40$???
jswjimmy
892
110 is the cheapest ive seen them
SinfulWeeper
4,539
$60 more is just a few dollars...
Or there are the FS/FT forums. A lot of times there are some sweet deals out there :).
jswjimmy
892
ill stick with air, my 1800 runs at 75F and the room is 80 plus its oc to 1.6 giz its the chipset harddrive and gpu i whant to cool.
SinfulWeeper
4,539
Here is just a tip (although I myself have not done it as I want to mount the radiator outside... too much work at the moment)
Waterblock (of good quality) ~ $30
Radiator ~ $10 (any automotive salvage place)
Hose's ~ $5
Water pump ~ $10-$40 (from a auto or plumbing store)
120MM fan for radiator ~ $15 (not needed because of my climate :p)
@ most, $100.
@ least, $70.
Of course YMMV. But I live in Alaska where everything is OOP. But I see no reason why you couldn't do it for the same or less, unless of course you fork over the extra money for a complete kit.
---Edit to add---
Never heard of them before. But water cooling is not rocket science, I see no reason why it wouldn't work :)
jswjimmy
892
this xmas ill do it. i dont have money now im only 14. i built this computer with birthday money. it shure beats my p2 350mgz. wow you live fare north i thought i had it bad in maine
SinfulWeeper
4,539
ASK THE COMMUNITY
