Cooling an AMD 2100XP (quietly ?) ----- (quieter than a delta 7000rpm)
I currently run a 1.2 T-bird with a GlobalWin WBK38 (delta 7000rpm fan) & will be ubgrading soon to an AMD 2100XP .
Looking for LESS noise with the upgrade .
So is there an HSF combo out there that is around 8-10dba lower than the delta's "44-46 dba" & give a little above average cooling ?
why don't u try buying a fan adapter. this means therefore allows u to use a bigger fan without having to get a new hsf. u won't lose much in CFM either.
i personally opted for the watercooling path. i'm testin my kit now.
i'm runnin my old tbird 1.4 @ 166x10 ~ 39C - alpha 8045
You can use a Thermalright AX-7 with Antec Stealth Fan. I have it running on my 1900+ and it stays very cool.
