Cooling a room
Status
Not open for further replies.
ChAoTiCpInOy
6,442
Let's say I have a room that has a lot of heat being generated in it. Is it better to get a fan to blow cold air from another room into the room or use the fan to blow hot air out of the room into another room?
mizzou
9,734
54
you want airflow
blowing a fan out won't be enough to decrease the pressure in your room to suck in air from other areas (possibly warm roof / warm outside air / warm basement air/ and maybe some cool air from doorway where fan doesn't blow air into)
lxskllr
60,715
11,089
I've been helping a friend out in his 19th century house, and he cools the whole thing using a window unit upstairs, and setting box fans up to distribute the cool. It's a little cluttered with all the fans, but it works very well.
mmntech
17,501
12
I have the same issue. My bed room doubles as an office/den. It's a heat trap as is but the electronics make it worse. Not sure what to do with it though. Not enough cool air coming up from the AC vent.
lxskllr
60,715
11,089
If you can't remove the heat source, ceiling fans work very well. They lower the APPARENT temperature at a modest cost.
mmntech
17,501
12
Yeah, thought of doing that. Depends how they've wired the room though since there's no ceiling lights.
edro
24,326
68
Blow cold air in.
The hot air will tend to escape naturally (higher pressure).
Status
