Cooling a car without air conditioning?
nanette1985
4,209
Yow, I would need to replace the condenser, compressor, and the evaporator, plus a bunch of hoses and belts - way more than the old minivan is worth. And it's not in the budget to get another car.
So, any suggestions for keeping the car cool? Parking in the shade, keeping the sunshade in, lots of water.
I can't be the only person on ATOT driving a vehicle without AC!
Sukhoi
15,342
104
Your car *may* have these things called windows. They generally open. Open them. Drive.
And what in the hell happened that would require to to replace your ENTIRE A/C system?! Put R-134a in a R-12 system or something?
mobobuff
11,099
My A/C doesn't work either. I roll down the windows, and deal with the messy hair and lower gas mileage.
When parking, leave your windows cracked so your car doesn't become an oven in the sun. It'll still be scorchingly hot when you get in, but at least it's vented a little. Also try those windshield blinders that keep the sun out.
nanette1985
4,209
Yep, the R-134a/R12 thing. It was my ex-husband's car, and turns out he did that when the AC needed charging a while back. He bought some kit off ebay. Bad idea.
The good news is the rest of the car is fine.
Thanks to all for the tip about "windows". I'm trying to think of some clever joke about windows not being installed. . . Anyway, opening the windows doesn't do much when sitting in traffic (NJ). Except to make it easier to yell at people.
I may try gluing a battery-operated fan to the dash.
mugs
48,920
46
That's important when driving in NJ. ;)
Your car should already have a fan.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: Kelvrick
Someone link to the car with an inverter and window unit
A window unit is far too small in capacity to cool down the cabin of a motorcar. 48-60 mbh (4-5 TONS) of cooling capacity is the norm. (I know the pic was a redneck type joke but some believe it. ;) )
sniperruff
11,644
no seriously i've seen a van with a small window-type AC hanging out back. i took pictures of it but they are on my old phone.
mugs
48,920
46
A window unit can cool a good sized room, but it can't cool a car?
Rubycon
Madame President
Aug 10, 2005
17,768
485
A car interior is like a greenhouse. Tremendous heat load. If the car was parked in the shade there would be no problem. :)
That's campers for you. :) Works great when parked at night for sleeping. :)
FeuerFrei
9,144
929
Make sure no outside air flows in through the vents. It's always warmer than window air and it's no fun having hot air blow over you.
Park in the shade wherever possible. Makes a big difference if it's not baking when you enter it.
Raduque
13,140
138
4-5 TONS? I find that hard to believe! The brand-new Trane unit that cools my parents ENTIRE house to 60 on a day that's 90-100 out is only 3.5 tons!
Edit: I also find it hard to believe that the compressor, condenser and evap core in my truck that's smaller then the ones in my 5000 BTU window unit are capable of 4-5 tons of cooling.
0roo0roo
64,795
84
build a suit cooled by tubes. water cooling ftw? use a small refridgeration unit to cool the water.
MrDudeMan
15,069
94
agreed. 4-5 tons is total BS.
