- Jan 12, 2005
- 17,305
- 1,002
- 126
I just replaced my 6800GS with a 7900GS. The local BestBuy had them for $150 and I had a $30 gift card so I decided top ugarde since it won't cost very much at all once I sell my 6800GS. This model has no cooling on the video ram at all. I purchased this set of memory heatsinks. I'd also like to upgrade the GPU cooler. I'm looking at these two:
http://www.newegg.com/Product/Product.asp?Item=N82E16835118117
-and-
http://www.newegg.com/Product/Product.asp?Item=N82E16835118001
First, will these even fit the 7900GS? I didn't see it listed anywhere on Newegg what cards these coolers are compatable with. Also, I use a tower case and my graphics card is upside down in the case. Will this effect the way the heat pipe cooler works? I thought they had liquid in the pipe so it would need the base pointed towards the ground to work, so I wasn't sure if the second cooler would work in my set up. Any other coolers that you could recommend? Thank you in advance.
*Edit*
Ok, I see on the second link under "Specifications" a compatability list. The first link doesn't say... can anyone confirm that this will work with a 7900GS? Any other opinions? Thanks.
-and-
*Edit*
