Coolers to fit Geforce 6800 GS?
Orrhias
Would appreciate any recommendations for VGA coolers that fit this graphics card, as Google has not turned up anything. My requirements are:
1. Must be compact size and not block any PCI/PCIe slots, my Asus Xonar D2, etc.
2. More effective than the stock cooler.
If reasonably quiet, that's a big plus, but I could live with some noise.
I'm afraid any cooler you find for this will either be used, or as expensive as just buying a much faster card new. Is there a reason you want to hold onto this old card?
Used is okay. Expensive is acceptable so long as it meets the requirements. I've done a legacy custom-build, so I'm used to both used and expensive.
I think this has finally been solved. Someone suggested:
Evercool VC-RF
Titan TIC-CUV3AB(DIY)
Both are the smallest coolers I've seen, so hopefully one will work!
