VirtualLarry
New rig is going to have:
E5200 CPU
gigabyte G31 mobo
2x2GB Gskill DDR2-800
WD 6400AAKS HD
Samsung S223F burner
Radeon X1950 Pro
CPU is likely going to be overclocked. Will attempt 12.5 x 300 = 3.75Ghz with it.
Currently, the ThermalTake 430W is powering:
E2140 @ 3.2Ghz, 1.425v (BIOS)
2x2GB Patriot DDR2-800
GA-P35-DS3R v1.0
WD 320GB SATA HD
LG 20X IDE dvd burner
Radeon X1950 Pro
So it doesn't seem to me like there is going to be a lot of difference. The CPU will be clocked at 3.75Ghz at probably 1.4v, as opposed to 3.2 at 1.425v, but it's a 45nm CPU that draws less power (in theory). I don't know if the G31 takes more or less power than the P35 chipset.
Just wondering about the relative quality of the CoolerMaster Extreme Power series versus the ThermalTake. The ThermalTake may be a bit underpowered, but they seem to have pretty decent build quality overall, and they do last.
The other question is, do I upgrade to the 500W now, if it's a good PSU (as good as the ThermalTake), in case the computer needs to accept a graphics card upgrade in the future?
E5200 CPU
gigabyte G31 mobo
WD 6400AAKS HD
Radeon X1950 Pro
GA-P35-DS3R v1.0
WD 320GB SATA HD
Radeon X1950 Pro
