Cooler X800 PRO???
Chocdelight
Just got an x800 pro and I was wondering what members are using to replace the stock cooler. Don't really want to install until I get a better cooler. Anybody pleas give me some input. Thanks
You may have got a bad card from the factory, it would be foolish to go though the trouble of replaceing the stock cooler on a card you may have to rma anyway. Besides, the stock cooler should work fine for stock clock freqencies; you should really give it a try first.
I agree with TheSnowman, espeacially if you dont have a fast CPU to notice the performance differences and your not OCing.
I have a ATI Silencer 4 from my Sapphire Toxic card that I could sell you.
Here is what it looks like --->
Toxic Cooler
The reason I am selling it is because I use water cooling. The cooler is basically brand new, the only time it was used was briefly before I flashed the card to an XT PE, I needed to check and see if the card would run 520/560 first beforehand.
LMK if you are interested
