Cooler Recommendation
MRGOOCH
2,292
Can you recommend a CPU cooler for the E4400. One that is easy to install,fits well and not overkill.
Cases and Cooling is the right place ... not CPU forum
-CPU Moderator apoppin
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
For 50$ you might as well shell out 10$ more if you ask me for the top-end product. For a little less cash you could buy the arctic freezer 7 pro which also does a pretty good job at cooling.
Ika
14,264
Not overkill? Cooler Master Hyper TX2 or Arctic Freezer 7 Pro. Both are pretty much equals and cost the same. Go with whichever one you like more.
MRGOOCH
2,292
Thanks for your advise. I decided to try the Arctic Freezer 7 Pro $35. It fits in well on the GA-P35-DS3R board. Easy to install and runs cool.
