Cooler Master RS-850-EMBA (MODULAR)
LT4CAMSS
122
As I understand it, the "M" in RS-850-EMBA implies Modular. If that's the case, why are all the links I'm finding showing this PSU to be standard rather than modular?
CAN ANYONE please help me find this power supply for a good price on the net? If I can't find it I'm going to be forced to purchase the OCZ 780W ModXstream.
Mr Fox
876
It is Available at NewEgg... But there is a small Problem.. It is not A Modular Supply
http://www.newegg.com/Product/...x?Item=N82E16817171017
Model
Brand COOLER MASTER
Model RS-850-EMBA
Series Real Power Pro
Spec
Type ATX12V / EPS12V
Maximum Power 850W
Fans 1
PFC Active
Main Connector 20+4Pin
+12V Rails 5
PCI-E Connectors 4 x 6Pin
NVIDIA SLI Support NVIDIA Quad SLI Certified
Modular Cabling Support No
Power Good Signal 100-500ms
Hold-up Time 17ms min.
Efficiency >85% Typically
Energy-Efficient 80 PLUS Certified
Over Voltage Protection Yes
Input Voltage 100 - 240 V
Input Frequency Range 50/60 Hz
Input Current 12A@ 115 Vac / 6.3A@ 230 Vac
Output +3.3V@25A,+5V@30A,+12V1@18A,+12V2@18A,+12V3@18A, +12V4@18A,+12V5@18A,-12V@0.8A,+5VSB@3.5A
MTBF >100,000 Hours
Approvals CE, cUL, TUV, NEMKO, BSMI, FCC
Features
Features World?s first six +12V rails for better power distribution in Quad-SLI and 2 ways server system
Four 6 pin PCI-E connectors offer great future upgrade ability
Compliance with the newest Intel standard ATX 12V V 2.2
Compliance with the newest SSI standard EPS 12V V2.91
Ultra-silent operation with intelligent 135mm fan speed control (< 16dBA)
Eco-design for energy and money saving by Active PFC.(>0.99)/high efficiency(>85%)
Multiple protection design (Over-Voltage, Under-Voltage, Over-Temperature, Over-Current, Over-Loading, and Short circuit protection)
Manufacturer Warranty
Parts 5 years limited
Introduction
The Real Power Pro RS-850-EMBA from Cooler Master is engineered to meet the power demands of the gamer into serious overclocking. It features the world?s first six +12V rails for enhanced reliable power distribution in Quad-SLI as well as 2 way server systems. Additionally, it allows stable and consistent performance with the multiple protection design that makes it virtually immune to over voltage, over current, and potential short-circuits.
The RS-850-EMBA provides maximum 850W of continuous power for the most demanding computer systems. It boasts an Eco friendly design that saves energy and money by providing more efficient power up to 85%. It is compatible with the latest Intel standard - ATX 12V V2.2 as well as SSI standard - EPS 12V V2.91. The reliability can be demonstrated with a MTBF of more than 100,000 hours
The cooling is taken care by an intelligent 135mm fan speed control that effectively dissipates heat silently (less than 16dBA). This is a powerful unit just ready to push the volts through anything you can put in your box!
Highlights
ATX12V v2.2 and EPS12V Compatible
Compatible with the ATX12V v2.2 and EPS12V standards, the COOLER MASTER Real Power Pro RS-850-EMBA provides maximum power stability to drive the latest Intel and AMD processors as well as other components for desktop and entry-level sever computer systems.
850W Maximum Power
A maximum power of 850W delivers safe, reliable output for ultra high-end computer systems.
Highly Efficient
Providing up to 85% power efficiency, the COOLER MASTER Real Power Pro RS-850-EMBA saves energy and may even reduce your electric bill!
Modular Cable Design
The modular cable design allows use of only the cables you need resulting in improved internal airflow and reduced system clutter.
Quiet Operation
An intelligent 135mm fan delivers whisper-quiet cooling and ensures quiet operation through fan speed adjustments in response to load conditions.
NVIDIA SLI Certified
The COOLER MASTER Real Power Pro RS-850-EMBA has gone through a series of rigorous NVIDIA SLI certification tests for maximum system stability when building NVIDIA SLI PCs.
Photo Gallery
Quick Specs
Maximum Power 801 - 900W
+12V Rails 5
Fans 1
PFC Active
NVIDIA SLI Support Yes
Detailed SpecificationsDetailed Specifications
Learning Center
Power Supply Buying Guide
* What Is a Power Supply?
* Power Supplies Types/Form Factors
* Things to Look For When Choosing Your Power Supply
* Our Recommendations
View All Learning Center information on Power Supplies Category»
Home
Home >
Computer Hardware >
Power Supplies >
Power Supplies >
Cooler Master >
Item#:N82E16817171017
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Go to Europe.
In the US, Cooler Master doesn't sell modular PSU's unless they're bundled with a case (seen the 1kW modular this way at Newegg.)
