Right now I'm just using the Intel 3000 on my 2600k CPU, no overclocking, using 16GB RAM, 1SSD and 1 7200 HDD.
I plan to get a EVGA 560 Superclocked, so before I do you all think it would be a good choice to get another brand PSU, I'd like to stay at 700 watt unless you all think that's just not enough.
That's not exactly true. You'd need to look at the +12V rail and see what wattage it's rated at. According to the advice that I got here (thanks lehtv), 480W on the +12V rail would be ideal for a GTX 560 Ti, so a superclocked 560 would be fine with that as well.700W is way more than you need, even 500W would be plenty.
The problem is that we don't know what PSU he's going for, so you can't just assume it's a really good one. And a 400W PSU for that system isn't fine when you're not calculating the maximum required wattage for 90% system load and 90% CPU TDP, which is recommended. And you're not adding a buffer to compensate for capacitor aging either, which is also recommended.Assuming good quality PSU of course, even 400W would be fine since the OP is not overclocking so the system will use less than 300W.
ok you're both talking way over my head so saying it in dummy terms, will this 700 watt be ok if I don't overclock and add on a 560 and a few case fans?
Yes, it will be enough with plenty of room to spare. Seasonic, Corsair, and Antec have PSUs with better build quality though.ok you're both talking way over my head so saying it in dummy terms, will this 700 watt be ok if I don't overclock and add on a 560 and a few case fans?
