- Aug 27, 2001
- 6,770
- 1
- 81
Hello, I just finished my new build (main in my sig) and I still have a lot of testing/drivers/etc... to finish. As the thread title states I'm using a CM ML120R AIO water cooler. Installation was fairly easy though I believe I used too much TIM, oh well, I may fix later. One thing I did notice after installing the gigabyte monitoring software was the the CPU can is behaving strangely. The temps would range between 32 and 48c on my 2700x with the fan speeding up each time the temp rose and then slowing down as it cooled off. The strange part is that these cycles were very fast, a few seconds in total. So the fan is fairly constantly spinning up and down as the temp changes.
I'm not worried so much about the noise, though it is somewhat annoying, more about why the temp is going through such swings so quickly. Could that be an example of a crappy installation? Or just the nature of the setup? I'd prefer the fan speed to be somewhat constant so I can adapt to it, but I'm more worried about the setup overall.
Any thoughts? Any thing I can do to test it better?
Thanks
Thanks
