braveheart0707
yes i know, the D14 is the king of air cooler, lol~
but due to the sheer size of it, i am thinking about getting the 212 evo instead because i am not only looking to do mild overclocking, and this so far seemed like a sweet spot between size and performance.
Couple questions if anyone could help me out~
1) how is the thermal compound that comes with it? the D14 comes with the Noctua compound which i think is pretty decent right? how about this one? worth using or need to buy a separate tube?
2) How is the noise? especially compared to the D14?
3) how much of a temp difference compared to D14?
cheers~ PS, the cpu i am planning is i5-4670k or i7-4770k, only plan to do some mild overclocking like 4.2-4.3ish, case would be Fractal Define R4
