Puffnstuff
I just moved my pc from a xclio windtunnel to a cooler master haf 932 and I've begun to notice buzzing in my microphone. If I touch the case while using the mic the buzzing is reduced. Has anybody else noticed a grounding issue with the haf and if so what did you do to resolve it? I double checked to make sure everything is secured inside the case so now I'm wondering if I should physically attach a ground wire to the case and run it to another point to ground to. I've never had a case do this before. Also I'm using the provided wheels on the bottom instead of the feet.
