Cooler Master Glacer 360
james1701
Has there been an approximate release date set on these coolers?
I need to replace my H100i and with this being released in the US, I might give this a go.
What's the MSRP (USD) anticipated for that bad boy? I think I'm getting the itch for a CLC like that.. . .
I have not heard. It will probably run for about what the Swiftech units did before they had to pull them from the shelves in the US for the patent problems.
I think its a bad move considering that not many current cases supports a 360mm radiator. To fit within the current standard mounting, CM should've gone with a 240mm/280mm radiator, higher FPI, thick radiator, or a combination of any of these three criteria.
Furthermore, running a 360mm radiator solely for the CPU alone is wasteful unless the user adds the GPU within the loop. That anemic pump will be its Achilles heel and may not be good enough to support the added restriction from the GPU block.
