Originally posted by: SerpentRoyal
Have not seen any thermal issue with Earthwatts or Trio. The DC outputs look fine on my analog HP scope. No report of squeaking transformer, either.
105C OST caps are very popular on ECS boards. No report of premature failure over the last two years.
It's normal for diodes to run @ 100C. I've only seen thermal issue with diodes on some DC resistance welders (EQ5240 from Square D in 1980s). The machine can provide 3600A @ 16VDC with 60' 350MCM cable. Yes...30-60KVA weld transformer the size of a shoe box.
Explain to me why the Antec bread board can shorten the life of the PSU? I have the Trio and Earthwatts. They share a lot of core components. A smart engineer would come up with one quality core design, capable of accepting additional circuits to tighly regulate voltage and current at minimal cost.
I never said there was anything wrong with OST. I merely said they're not "great." I had said that there were actually very few brands known for leaking over the long term. OST is NOT one of them.
I'm also citing generalizations for using sub-standard components like diodes, transformers, etc. Not the Antec specifically because, like you, I don't know the specific components because I haven't taken one completely apart. Of course, I could if I had to.
As for thermal issues with diodes; if the diode is run near or at it's peak thermal temperatures, it's performance is going to fall off and/or eventually fail. Even the best brand diodes have an operating temperature of up to 125°C and have a drastic fall off at 110°C. If you've only seen the problem with some welders, you need to expose yourself to some more PC power supplies. Perhaps NASA power supplies are more up to snuff, are provided with better ventillation, etc. but in the PC arena it's save money at every possible opportunity yet still maintain a small size and low noise characteristics.
As for the PCB, cheaper PCB's with fewer layers have known issues. Greater transients, increased EMI, etc. Does that mean that Antecs have known issues? Certainly not. But you were making the implication that the Antec is the same as the Corsair, with the only difference being that Corsair is marketed as a higher end unit and I'm telling you that that's an incorrect assumption. One glaring difference IS the PCB and that's all I was pointing out.
