Cooler Master Elite 331 & CPU Cooler
f650blue1
Hello,
I'm looking for a cpu cooler for my cpu (AMD Llano A8-3850) The case is the cooler master elite 331, the mobo is an Asus F1A75-V Pro. The maximum height of the cpu cooler for this case should be no higher than 166.6mm, according to the case manual. I like the price to be $30 to $35 if possible. I just want to use the turbo mode on the cpu. Can you recommend one that is compatible for this set up?
Let me know if you have any questions regarding the system.
Thank you for your help.
