Hi, all
Can someone explain how air flow works in this new case?
Are both the 120mm fan and the side 80mm both in-take fans? The recommended setup for a non-water cooled rig is to mount the PSU with its fan facing up. If this is the case, how is hot air going to be exhausted from the case? Does it rely on positive pressure?
Thanks in advance for any feedback.
