Cooler Master DP5-6H51
tigereye
327
Just wondering if anyone has any thoughts about this cooler? Is it an ok overclocker? Building a Duron 700, hoping to get it to at least 930.
Thanks,
Tiger
h0vic
735
The Coolermaster HSF is not the best choice for OCing. I would suggest going with a Globalwin FOP-38, Alpha PAL6035 or PEP66, Kanie Hedgehog, TaiSol CGK or the new Vantec. Switechs are good, but they cost way too much.
Take a look at Mike's HSF ranks. He's an expert on HSFs.
I'm debating on whether to get the TaiSol or Alpha. I've too many stories about Globalwin's pain a$$ clip. The Hedgehog are a bit too expensive. The Vantec uses a 38CFM 46dBa fan which is very LOUD!
Edit: Don't get the SuperOrb or ChromeOrb.
2CoolTek has a well done HSF testing.
zzzz
5,498
Though everyone on this forum bashes the DP5-6H51, I had great success with this heatsink.
I had a duron 600@1000 with it.
Now I am using PAl6035 and Taisol 742. Both are good. If you are tight on budget, get the coolermaster. IMO, there is no point in spending $30 for a heatsink to use on a $40 processor.
If you are getting a high end T-bird, I will suggest you spend the extra cash to get better cooler.
tigereye
327
Thx for the replies guys. Budget is one of my primary concerns. I've seen the Cooler Master for $15 shipped. The others are coming in at $20-$25 before shipping. I guess $10 isn't really too much, though.
Dan
tigereye: For what it's worth, I use Cooler Master's DP5-6H11 HSF on a Duron 700 that's been stable at 1083MHz for 3+ months.
Pauli
836
I use this cooler on a PIII-700 and it works very well compared to the retail HS/Fan.
tigereye
327
I'm wavering back and forth between this one, and the fop-32 for a couple of bucks more, will probably spend the $5.
Phunktion
2,502
Go with the fop-32 if it's only $5 more because then you'll have a more reliable HS for overclocking..
