COOLER MASTER Centurion 534
details at CoolerMaster.com
Side Fan, Rear Fan, Side Air Duct.
One 120x120x25mm front fan (intake)(Optional)
* Would it be tricky to add the front fan ?
Looking at the picture and CoolerMaster.com,
"Special mesh design with blue LED"
The LED appears to be rather mild. I don't want an obnoxious light coming from the case!
* If you own this case, how would describe the intensity of the LED?
* How difficult would be to disconnect / disable the LED without messing up the Power Button wiring?
Dig
Dig
