As a mobil heavy equipment mechanic i've had to work around some very poor engineering.
Things that were designed with little or no thought given to maintainance or repair. My preferance is easy and simple.
From the pics you linked and reading part of the review at spcr this case comes up to the
standard of an average case.
A 92 would be a very tight fit at the lower front(i think)and if one could be fitted it would best be a 92x38. It might have to stand off of the front inner panel using long bolts with some type of shrouding between the case and fan. I just started using the very thick and stiff cardboard from cigar boxes in some of my experaments. Cuts well with a fine bladed hacksaw and will bond in place with 5 minuet epoxy. Too much work to save a few bucks.
Emotionally the case is a turn-off because i'm a UCLA fan and don't care for USC's Tommy Trojan:laugh:
The bays are top to bottom to lend the case structural integrity but cases made this way block the intake fan when the bays fill-up.
Three things should be at the top of anybodys buy list for a system they will live with.
1-The best monitor/display one can afford as this is what we look at and most will have the one they chose a very long time.
2-The case because it may live through several up-grades.
3- The PSU is nearly allways an after thought and this is the guy that feeds the clean strong current to our highly prized componets. It will be around for several up-grades also.
Note: Welcome mikemcc to our forum.
The top bracing on the PC-7 is not a big deal. Drill out the four pop-rivets, they are aluminum so take it easy, then reinstall with flat head 6-32 screws. The top panel mounting holes will have to be counter sunk using a drill bit twirled between your fingers.
Do not use a drill motor for this as it will just grab and blow right through the thin aluminum panel.
I cut pieces of 3/4" aluminum angle 1.5" long, mounted them using the three holes on each side of the inner panel, then made a cross brace out of 1"x1/8" aluminum bar stock.
Bolted it all together with 8-32s, used a framing square to make sure the case was true.
Be sure nothing of the cross brace is above the top of the inner panels edge as it will hit the top cover panel. The brace will block the access to the blow hole. I mounted a 80mm from this brace facing the PSU intake.
Galvanized
