Cooler for Laptop(Macbook Pro)
imported_pez
110
Hi,
I have a 15" Macbook Pro, I use it for gaming so it gets pretty warm
I got a cooler, specifically this antec one
http://www.newegg.com/Product/...x?Item=N82E16834999850
The fans are in the middle, but the area that gets hot the most is the near underneath the monitor, I suppose the graphics card is here?
Would it be worthwhile to get a different cooler that would blow air on this area more?
Thanks
VinDSL
4,869
www.lenon.com
Personally, I use a Vantec Lapcool 3...
The one you chose will work okay on a table, I guess, but forget about using it on your lap!
Get it? Lapcool?!?!? :D
VinDSL
4,869
www.lenon.com
Originally posted by: Zepper
Does it give your nads some air as well, vin?.. :laugh:
Heh!
Put a modern lappy on your lap, and you won't be gaming very long - they're flamethrowers! :D
I used a breadboard for a while, to kill the heat, but the %$#& board just got hot, blah, blah, blah.
There are LOTS of notebook coolers out there, but unless you're sitting at a desk, you need air intakes on the sides, not the bottom!
Just something to think about... that's all... ;)
