cooler for d1 chipset?
Kledgie
My mobo utilizes a Hudson d1 chipset, the e240 gpu. What's a good option for an aftermarket cooler for this thing?
correct me if im wrong, but isnt the heat sink glue'd to the cpu?
does it have a means of removal?
You may need to look at chipset heat sinks as a solution, because the hudson's are sort of like the nuc's and was not intended to have heat sink removed.
Thanks for getting back to me. I believe it is removable and not glued. At least that's the case with mine.
I'll look into the heatsinks
