Cooler for Conroe
Dufrane
378
What a good cooler for a comroe 6400. Will not be overclocking and would like it kinda quiet. Is the one that comes with it any good???
eelw
10,423
5,555
If you use Speedfan to slow down the stock HSF, it is very quiet. At 100%, it runs around 2500RPM but is noisy. At 50%, it's around 1500RPM and is quiet. And when set to 0%, it runs at 900RPM it is silent.
n7
21,281
4
http://www.almico.com/speedfan.php
SpeedFan is a freeware program that monitors voltages, fan speeds and temperatures in computers with hardware monitor chips. SpeedFan can even access S.M.A.R.T. info for those hard disks that support this feature and show hard disk temperatures too, if supported. SpeedFan supports SCSI disks too. SpeedFan can even change the FSB on some hardware (but this should be considered a bonus feature). At the lowest level, SpeedFan is an hardware monitor software that can access digital temperature sensors, but its main feature is that it can change fan speeds (depending on the capabilities of your sensor chip and your hardware) according to the temperatures inside your pc, thus reducing noise. Several sensors, like Winbond's and the AS99127F support fan speed changing, as well as others from Maxim, Myson, Analog Devices, National Semiconductor and ITE, but the hardware manufacturer must have connected the relevant pins to some additional, yet trivial, circuitry. This means that if you have, say, a Winbond W83782D on a BP6 then you're ok, but not every motherboard with such an hardware monitor chip will be able to change fan speeds. From one of the very first hardware monitor chips that could be found in standard PCs, the National Semiconductor LM75 (and all of its clones, like the Philips NE1617 and the Philips NE1618 or the Maxim MAX1617) or the Analog Devices ADM1021, such chips have been greatly improved, both in their precision and in their capabilities. Current chips can monitor fan speeds, voltages and change fan speeds by using PWMs (Pulse Width Modulation). Some chips can even be programmed to vary fan speeds without any additional software intervention. If your BIOS was programmed to setup such chips this way you can still try to use SpeedFan's Advanced Configuration to revert to manual (software controlled) mode. Winbond W83697HF, Analog Devices ADT7463, SMSC EMC6D102, ITE IT8712F, National LM85C and Maxim MAX6650 are very good candidates. Some SuperIO chips include temperature sensors too. SpeedFan can automatically detect them and use their features. SpeedFan can find almost any hardware monitor chip connected to the 2-wire SMBus (System Management Bus, a subset of the I2C BUS) Serial Interface and to the ISA BUS and works fine with Windows 9x, ME, NT, 2000, 2003 and Windows XP. It works with Windows 64 bit too. It can be minimized to the tray and is compatible with Motherboard Monitor 5.
cmdrdredd
27,052
357
Originally posted by: Dufrane
Thanks. Would you use an after market cooler???
If you get an aftermarket cooler you can get a Scythe Ninja or Mine.
Or a Thermalright SI-128/120 or Ultra-120 (have to get a fan to go with these).
Or on the cheap a Arctic Cooling Freezer 7 Pro.
The top end coolers range from $36 to $50. if you're not overclocking the stock fan is good, but won't get you good temps.
I'm using the stock cooler with my e6400 and it's ok. Hot, but ok. The Zalman CNPS9500LED absolutely blows...so I am using the stock cooler.
Baked
36,052
17
Budget: Artic Cooling Freezer Pro 7
Goody: Thermalright Ultra-120 w/ Yate Loon D12SL-12
rudder
19,441
86
The stock heatsink does and excellent job. Although it can get a tad load when you push the cpu in a hot room. Most times it is so quiet I can hear the hard drive heads. The one complaint I have is the retention mechanism. Its secure now... but it kept liking to pop out of the holes onthe motherboard when I was trying to secure it initially.
