Here's reviews of each from Frosty Tech. Read both and then decide. IMO, the Hyper 212 Plus is worth the extra money, better performer, better mounting system (no push pins), better fan clips, and a 120mm fan. It is tall though, 158.5mm (6.24 inches), so make sure your case is wide enough. http://www.frostytech.com/articleview.cfm?articleID=2419
