Coolbits and Overclocking
Corsair
203
Ok I have a geforce 3. The slider bar on coolbits only has a range between 175-250. I want to know if there is anyway to modify this range to be able to take it to higher clock frequencies. I know the card will do it. I run perfectly stable at 250 and want to be able to just push it a little more.
thanks
Scooter
1,699
There's no way to hack it any higher than 250mhz? I, myself, don't really care for third party software to OC, if I can prevent it. Anyone else have some insight?
CalebTG
624
NVmax is the best utility for the job.
It is a fully tweaking program dedicated only to nvidia cards.
It will allow you to go up to 300core/600memory
Check it out at NVmax.com
<edit> Sorry, its kinda hard to find on the site [ironicly enough] so here is a direct link; NVmax 2.094 </edit>
<edit2> Damn, even that link is down. Just search around for NVmax, I'm sure you'll come across it somewhere. </edit2>
