Cool case for $22 Front USB Almost screwless
Gator36
51
I was a bit sceptical, but for $22 (no power supply) I was willing to try.
EVERCASE E4252W005, Intel P4/AMD, 10-Bay, Truely Screwless ATX MID Tower Case. BEIGE. No Power Supply.
The locking mechanisms work well. Even the expansion slots have a holding bar so there are no screws there. The two front usb ports are single pinned so they will fit any motherboard. The drive cage slides out without screws but I had to screw the hard drive to the cage.
If you need a power supply, I've have the 300W Heroichi Electronic corp. Power Supplies and it's impressive.
Gator36
51
It's hard to tell what a case is like from a picture. I posted because I've built a system with the case and liked the quality.
Bad Dude
8,464
I wish the shipping was not so high as I only live around 25 minutes from them.
