Originally posted by: Capt Caveman
You can't really ruin tofu. Personally, I like mine firm and a little bit crispy on the outside. So, I'll cook it separately using fairly thin strips and let the sides brown. Then add it to the rest of the meal.
You are just heating it up. However, it would taste bette if the tofu are marinated in your favorite sauce/herb (or your own concoction) first for at least 15 minutes, then gently cook it first then add it to the rest of thr stirfry.Originally posted by: joesmoke
when does the tofu go in? its my first time cooking it. does it really need to cook or am i just heating it up at the end with the noodles? its been marinating so id like to get it in earlier, but not if that will ruin it.
Originally posted by: Pepsei
my favorite technique is to deep fry the tofu pieces first.... it makes it really easy to work with and will retain more delicious sauce.
pan seared is alway good too, but it takes a little finesse to not break any pieces off. i usually add some spring onion while searing and when you browned the tofu on both sides, add soy, mirin and then top with cilantro. cut your tofu like pic.
OHHH!!! Deep frying first... sounds good. I should try that.
How do you deep fry it? Do you marinate it first, then batter it at all? or just drop it in the oil?
Not true. You can definitely ruin tofu.
Deep-fried tofu is really quite tasty.Originally posted by: silverpig
Correction: tofu is pre-ruined.
Cooking + tofu = fail
what are you cooking?
You don't know tofu.
garlic, ginger, broccoli, mushrooms, red/green bell peppers, tofu and udon. ended up adding the tofu right after the veggies (after marinating it in sioux-z-wow sauce). turned out pretty good, but i think the tofu could have been cut smaller and marinated longer. the tofu itself didnt take on much flavor, ended up still kinda bland.
thanks for all the great ideas... i think marinating longer + pan searing is what i SHOULD have done.
deep fried sounds interesting!
Tofu is supposed to be blandThere are many ways to do tofu, from what you described, did you create a sauce for the noodle? If so, you have to starch the sauce. Or was the noodle a stirfry? If stirfry you would use the dried tofu, not the soft one.
well, sorta. right before adding the veggies i used a lil soy sauce and oyster sauce. I do the udon (noodles) seperate, then add them right before its done just to heat them up and coat them in the "sauce".
Whats starching, just adding starch to thicken it up ? water too? im assuming to make it "stick" to the tofu better? Would that work with what i described? (soy n oyster). thanks for the info!
