cookie problem
fitzm
When I try to log in to my home page this is the message that I get:
<< OOPS! THERE'S A PROBLEM.
Either your "cookies" are not turned on, or we have experienced a problem reading them. Please check your Web browser settings to make sure they are set to accept cookies. You can still use the site with your cookies turned off, but you will not be able to collect entries for the sweepstakes.If you're sure that your Web browser is set to accept cookies, please send us a message with the Web browser name and version number so we can assist you further. You can access the Customer Service feedback form here.
For Internet Explorer 5:
1.Click the Tools button on the top menu bar of your browser.
2.Next, select Internet Options.
3.Click on Security.
4.Click on Custom Settings...
5.Scroll down until you see "Cookies."
6.Set "Allow cookies that are stored on your computer" to "Enable."
Everything is set as they said above. I really don't care too much about this site but I can't get into "live scoring" to watch my progress in my fantasy league on sportsline because I can't get past sign-in. When I log into sportline's fantasy page my username and an empty password prompt box tells me I "need to be logged in as fitzm" , which I am. But after I type in the password it just comes back to the need to be logged in message. I've tried restoring defaults in internet options but that didn't help and cookies are enabled.
help!
Try clicking on the Privacy tab and see what level of security you're on. If you're on High, all cookies will be disabled. Medium-High should allow cookies. Check to see if you have blocked any cookies. Hope this helps.
If your using an internet security/virus scanning program or firewall make sure it's not causing the problem. Also, I upgraded to I.E.6 and it has been the best version of I.E. I've used although that still isn't saying that much 😉
