- Jun 8, 2012
- 464
- 0
- 76
Hi,
I am utilizing ServiceNow JavaScript to try to convert Base64 to Base64Url. I cannot use any dependencies since it's all within ServiceNow tools.
I came up with this and it seems to work with all the tests I used. Is there any glaring problems?
GlideStringUtil.base64Encode is a native way in ServiceNow to convert to base64. Once I have that, I make an attempt to convert it to base64url so I can pass it to Azure DevOps.
var bodyBase64 = "This is a string to convert to base64!!!!!!"
var bodyBase64 = GlideStringUtil.base64Encode(body);
function convertobase64url(bodyBase64) {
//replace any instance of / with _
bodyBase64 = bodyBase64.replace("/", "_");
bodyBase64 = bodyBase64.replace("/+", "-");
bodyBase64 = bodyBase64.replaceAll("=", "");
return bodyBase64;
return bodyBase64;
