Converting AAC files to MP3 with no loss in quality?
Runes911
1,683
I have some AAC files that I want to convert to MP3 without loseing ANY quality, can this be done? They are unprotected files.
Slick5150
8,760
Not really. Both are lossy formats so you will lose quality when converting.
That being said, using the Lame VBR encoding, it shouldn't be a particularly noticable loss.
Traire
361
By the technical definition of MP3, no, MP3 is not a lossless codec.
FLAC, Monkeys Audio, ALAC, and WM9 lossless are the only lossless audio codecs I know of.
0roo0roo
64,795
84
yea if you can convert it into lossless format. less than optimal space wise but its the only way not to lose a bit of quality.
Runes911
1,683
Well then my next question is is there a Portable player that can play AAC OTHER than IPOD? I don't want to buy and IPOD they are stupidly expensive compaied to other mp3 players of the same quality, size, space.
Or how about converting AAC to a format that can be played in a normal MP3 player and not IPOD only?
Traire
361
The truth is, unless you have some above average hearing, encoding into VBR WMA9 or OGG Vorbis at higher than 128 kbps will probably sound just fine to you. There are a lot of audio players that handle both WMA and OGG Vorbis.
Runes911
1,683
Do you have a program that you would recommend?
