Converting 220v to 120v for computers-What do I need?
letsgetsilly
397
A friend is bringing a computer the the US from overseas. From what research I have done, I have found that he will at least require a step-up transformer to change the voltage from 120 to 220.
I remember reading about the changing cycles (Hz) that could damage my laptop if it didn't have the big converter built in on the power cord/supply. I'm wondering if there needs to be something similar for a desktop computer?
Any suggestions on this are greatly appreciated, thanks in advance!
wamasters
26
Many power supplies have a switch (on the back of your computer) allowing you to switch between 110 and 220. Tell your friend to check for that. Otherwise, change the power supply to a 110 60hz model (it's a better/safer solution to the problem - power converters are NOT a reliable , permanent solution).
GalvanizedYankee
6,986
If it's a desktop computer...Find out what brand and model of PSU he's running.
Some PSUs just need a different power cord and can be plugged into 120, others have a switch at the rear of the PSU and one selects 115 or 230.
The monitor and/or peripherals will need a convertor.
...Galvanized
letsgetsilly
397
How will the monitors react to a converter where the power isn't necessarily consistent.
Also regarding the 115v...is that sufficient? Doesn't it require 120v? With saying that I realize that I have dealt with computers that are set on the 115 v, but it doesn't make sense.
kd7fhd
339
As cheap as monitors, printers, etc. are, just get new ones here. Saves the trouble of packing them up, also. I just bought a 19" NEC MultiSync MS95 at a yard sale for $20. Printers go for $10 & up.
flexy
8,464
155
you need to check the specs of your PC *and* monitor.
They either have those red tiny switches to switch 'em from 220 to 115...OR (if they dont have a switch) SHOULD do that automatically.
Eg. a typical monitor spec is
Power
Form Factor Integrated
Voltage Required AC 110/220 V ± 10% ( 50/60 Hz )
means it accepts 110 and 220V, so it's suitable for the us and europe.
All you need is standard power-cables with an US/EU plug for the monitor and the PC.
WackyDan
4,794
68
Cycles, either 50Hz or 60Hz really has no effect on solid state devices like a modern computer.
Relays, and other electro-mechanical devices on the other hand, can really be FUXORED.
Fans won't present a problem however.
So, provided your friend isn't bringing a monitor with them, you probably can just swap in a new power supply, if the existing supply is 220/240 only.
If they are bringing a monitor, and it's a CRT, it most likely is 220/240 only. If it's an LCD that's not too old, it stands a good chance of being both 110-240. It should be printed on the back of the bezel, or on the power brick if it uses one.
A good step up transformer that will handle CPU, and monitor is expensive. A decent Power supply will certainly be cheaper, and be a healthy upgrade to his system.
