Conversion of a Radeon 8500 to a Radeon 9100
Thavian
9
I've heard that it's possible to convert a Radeon 8500 board to a Radeon 9100 board using a BIOS flash, since the 9100 is just a rebadged 8500. I have two questions.
1) Does this only work with third-party 8500-series boards, or does it work with ATI-branded boards as well? I ask because ATI never made its own 9100 board.
2) Does this work with the All-in-Wonder series or only with the normal 8500?
Thanks.
JeremiahTheGreat
552
yeap...
i did the same. No difference.
Only works on any Non-AIW 8500's, just watch out for the mem/core speed difference of the bios, cause some cards can't handle the increased - if you have one of those horrible 8500LELELE models
SickBeast
14,377
19
Originally posted by: Wag
Same card, I did it- no difference. Don't bother.
My scores actually went up a bit. The 9100 bios is newer and has more aggressive memory timings. I can email you the files you'll need to do it if you want.
bunnyfubbles
12,248
A retail original Radeon 8500 64/128MB is clocked 275/275 which I believe is actually higher than that of most 9100s... in otherwords they are the same thing with the 8500 still possibly being a little bit better...
spanky
25,716
4
huh? i thought the 9100 had crappier ram.
Johnbear007
4,570
Originally posted by: JeremiahTheGreat
yeap...
my 128 mb LE has BGA ram and runs stable at 300/300
HappyNic
641
yeap...
but does it have DVI out-put? :D
BFG10K
22,709
3,002
It's the same card so don't bother, especially since you lose warranty support the minute you flash the BIOS.
