control panel settings
icyredsol8181
173
i have a 9600 pro and i was just womdering what i should set my opengl and direct3d too? and by the way is battlefield direct3d or opengl? and what resolution to have, all i play is battlefield 42(desert combat). i was just wondering what you guys have yours at? thank you
azntiger0586
343
well it'll be hard to tell you what to run at because you havent stated any system specs.
bf1942 should be running in opengl.
for standard, try running these settings under opengl tab:
1024*768 (32 bits)
anti-aliasing: 2x
aniso: 16x
Quality
vsync on (or default on)
truform: off
Mem
21,476
13
nobody has never messed with their control settings?
Yeah,but it depends on the user and his PC specs etc and what he prefers,I use 16x AF performance setting,Trueform off,AA set to "application preference" and all the other sliders on max (highest quality).
high
Banned
Sep 14, 2003
1,431
I'm using exactly what Mem is using and it runs like a dream on a 9800np
VIAN
6,575
Run at the optimal resolution of your monitor along with the optimal refresh rate.
AA2x, AF at max, vsync on, truform off, everything on quality
these settings look the best IMO. Your performance may suffer a bit - then you will have to tweak it on your own.
Challenger
3,044
51
I noticed that you guys are turning the vsync on. I thought that would hinder performance and drop the FPS?
GullyFoyle
4,362
11
But it will look so much better, especially if you like to fly planes. The faster you move the more things skip and hop across the screen (with VSync off).
VIAN
6,575
The loss in performance is minimal if any, I haven't noticed anything. You get a smoother gameplay with it on.
azntiger0586
343
vsync on will give a more stable fps and less image tearing
BFG10K
22,709
3,007
All Radeon owners should use 16x performance AF in all games because it's so cheap and extremely good looking. Then experiment with AA on a per application basis if you like, though I'd suggest higher resolutions as a priority. Also keep Truform off and use maximum texture and mip-map details.
Vsync can dramatically reduce performance and increase input lag. Leave it off unless you get excessive tearing.
