Contact pads on Intel CPUs - front side
Sheep221
1,843
27
Since introduction of the first i7, every Intel CPU since then carries gold contact pads also on the front side randomly placed around the IHS, I never found out what is their purpose. Any ideas? Googling didn't reveal anything.
Mobile CPUs have them as well:
Wall Street
691
44
I believe that they are debug test pins which I would assume are used in the validation & binning processes.
VirtualLarry
56,587
10,225
Yeah, they're for packaging and test, validation, debugging, and probably micro-code programming.
pcgeek11
22,392
5,004
If I remember correctly there was a time when you could use conductive ink to connect some of those to unlock a processor at least on AMD Processors.
VirtualLarry
56,587
10,225
I'm pretty sure there is no microcode, as that gets loaded first thing via bios.
Uhh, the CPU has to have a built-in default microcode, otherwise it wouldn't boot the BIOS.
The BIOS can load subsequent microcode patches into microcode SRAM, but the CPU needs a stock microcode to boot, AFAIK.
Sheep221
1,843
27
This is correct, but instruction sets and so on I know are hardwired in the silicon.
I thought it has something to do with post manufacture configuration but wanted to know more details. As from the pics above every socket has them placed in different pattern.
can't check electrical behavior manually because socket and cooler block them.
Maybe Dresdenboy will know.
