- Apr 6, 2002
- 45,187
- 12,464
- 146
So, I have had two drives on my file server give me problems, both Seagate, within the last couple of weeks. One goes chirp, chirp, chirp, chirp.. whirr 3 or four times before calming down, but is not recognizable. Windows Computer Management shows the disc as 3.99TB, but it's only 1.5TB. I'm unable to format the drive. It asks to initialize the disc, but errors out. Not sure what is wrong with the drive, but it seems like toast. Unfortunately, it's out of warranty. It was a replacement (Recertified) RMA drive for another failed drive. It's not like the new ones have that long of warranty any more unless you get WD Black drives. The other problematic drive is another 1.5TB drive that occasionally disappears in Windows. I shutdown, disconnect the SATA cable, boot up, shut down, reconnect the SATA cable, boot up and the drive shows back up, only to disappear later. I wondered if it could be the controller card. Hooked it up to an onboard controller. Same results. Worked for a while and then the drive would disappear. Weird.
Anyways, it seems that I need to purchase some new drives. As I normally do, I plan on migrating towards larger capacity drives. Currently, I've got 4 x 1.5TB HDD, 4 x 2TB HDD and 1 x 128MB SSD (for boot drive). Speed is not a concern at all as this will be for storage only. Reliability is a concern as is cost. What I'm looking for is a recommendation for 4TB consumer drives.
