Did you like it better when the quality of the circuitry and the video encoder in the console mattered or do you like having HDMI better?
I'd say analog when done right is better than digital, but digital is better than analog not done right. If you got really good output circuitry quality and the best video encoder in a console, then that was better.
The advantage of HDMI is that the quality of the circuitry in the console doesn't matter. A disadvantage with HDMI is the lag from the TV's processing and the fact that the output quality probably isn't quite as good as using an RGB cable with a console with great circuitry quality and a great video encoder. For example, a Genesis with the best video encoder and great circuitry (wired how it's supposed to be, good caps with no leakage, etc.) hooked up to a good CRT with an RGB cable would give better output quality than any digital connection to any LCD currently in existence would with no input lag caused by the TV. However, caps generally tend to degrade after time and you could never trust the console manufacturers to always use the best video encoder possible and for them to always use the right output traces, the best caps, etc.
I imagine the Wii will be the last console in which the DAC/encoder quality will have mattered (since all but the earliest X360s used HDMI).
