StraightPipe
So I've got a 100mb network setup in myu house w/ 4 pc's 1 mac, and a PS2. it's all connected to DSL using a linksys router, and a gigabit switch. everything works great, but i really want to improve transfer speeds between my 2 pc's. i recently added RAID0 so it gets transfer speeds up to 85MB/s x 8 = 680mb/s. my older system is still regular IDE, and gets transfers up to 55MB/s x 8 = 440mb/s. (considering upgrading to SCSI on that one).
my new system has onboard gigabit (dell mobo).
I've been looking at switches and nic's, and have found this trendware 1000 switch for $70 after rebate(plus $5 for s&h)
also i found several nic's ranging from $28+5 for EDImax, or $43+5 for Intel all at newegg
Questions:
can I just connect the 2 via crossover cables, or do i need to fork out $75 for a switch too (i'm perfectly happy with 100mb's on the other pc's)
do i need cat6 cables? or if i stick with cat5 will that bottleneck me? I'd like the network to be fast enough that the RAID drive will be the bottleneck (planning ahead to get a faster drive system in the old box) so i want to be able to get 680mb/s.
i realize to do this i will need a minimum of one gigabit nic (for my old rig), and a 100mb nic for my new pc. that way i could connect the to each other using crossover cable, and onto my existing network using 100mb.
my concerns ar that have both computers on both netowrks if i request a file transfer how will the systems know to send it on the gigabit LAN, and not the 100? they need to be on the 100netowrk so i can get them on the net. (ICS through one of these boxes isnt feasable since the old box is used for serious downloading, and i dont want to have to realay through either.
does it make a difference which NIC's i pick? please tell me i dont need the switch /wallet begging for mercy
Questions:
