- Mar 17, 2011
- 1,777
- 76
- 91
Since I moved into a friend's house and now have my computer in my room instead of about the open 800sq.ft. that my apartment did, I have to keep my door closed due to kitty cat relations (or lack there-of >.<). Also, due to the lack in air floor in the room I'm in and summer months quickly approaching, I've noticed my heat levels have dramatically increased on my GPUs and CPU; not to mention the fact that it's getting hot as fok in my room.
Any and all advice is appreciated. I've read the water cooling basics on here and understand the basic needs, so my questions here are more specific to my case and other's experiences with it.
My case.
Can anyone share their trials and tribulations with water cooling this case?
I'm considering doing it fully custom and here are the notes in what I've come up with so far:
- 2 radiators (front bottom @intake fans and rear below PSU - reversing rear case fan; case fans I'll be replacing from stock to increase air flow)
- 1 pump stored in the lower area of the 5.25" drive bay (shielded for critical failure protection)
- reservoir in 3.5" drive bay area (shielded for critical failure protection)
- all components will be mounted to the case for purposes of travel and stability
- I run 2 GPUs in Crossfire and plan on keeping it that way in future upgrades (is 1 pump enough?)
- I mildly overclock, however, if watercooled I'd probably push it further just to test
Thoughts? :hmm:
My case.
Thoughts? :hmm:
