- Feb 22, 2008
- 2,846
- 4
- 81
Just upgraded my main PC, which bumps my work PC out, which I can either sell (waste of time), or re-purpose for a server. Ive looked into FreeNAS a bit, and know Ive got some parts that would definitely be good, but unsure about others. I want to run a Plex server from it (no more than 1 or 2 streams needed). I also only need maybe 6-8TB or so for now (I was thinking of buying three 4TB hard drives to use - cant remember what raid configuration that is)
Here's the computer that Ill be using:
Processor: Intel Pentium G3258
definitely good enough for my purposes (also it will be overclocked)
Motherboard: MSI H81M-E34
unsure about if this is OK. I only need 3 Sata ports, so I think im good. Pretty sure this takes ECC RAM - not sure where to find this info though.
CPU Fan: H212 EVO = fine, whatever
Memory: Crucial Ballistix Sport 8GB (need to upgrade)
definitely need to upgrade to ECC RAM. Ill probably go with 8GB? I read somewhere that you should go with 1GB for every TB of storage - so this seems ok. If not ill spend a little more on 16GB. Does this benefit from dual channel as well? Should I just get 1 8GB stick?
Graphics card: not needed
Case: Antec 900 - fine
Power Supply: Corsair TX750 - maybe overkill, but fine
Hard Drives: none right now
I need recommendations here. Like I said 6-8TB of storage is what im looking for. I have some other drives, but I'd rather get 3 new drives for the purpose of this server.
USB Drive: Will any decent usb drive do? Ill order a new one if I have to, but I already have a bunch.
How are my parts looking so far? Is there anything im not taking into account? Not trying to break the bank here, but im estimating my costs as such:
8GB of ECC RAM: cant find a decent kit?
or 16GB: $130
4TB hard drive $140 each?
Thanks in advance!
or 16GB: $130
Thanks in advance!
