Consider helping out a small problem
nvfx
Banned
I cannot run the Ruby: Double Cross Demo on my GigaByte X800 Pro.
Whenever i run it, it just exits back to the desktop and opens a notepad file with a description of errors.
I cannot understand the errors but i would like to know what is causing the Demo to fail.
I am running Catalyst 4.8 + Control center.
the demo didnt even run on Catalyst 4.7 drivers.
Plzz help me out.
Also, is it true that the Ruby Demo is only for the XT PE's.
i remember i couldnt run some of the r300 demos.....i think i made sure it wasnt overclocked, put the texture quality to higest, turned aa and af of then modded the configuration file for the demo's to run at a resolution my monitor supported....my monitor would not do 1280x1024 only 10x7 so i jus edited that an they all worked fine
either way its no great loss......play games in stead....u cant play ruby......dirty boy!
