Conroe using stock heatsink/fan
shadykidd
82
Every post about a Conroe PC build has an after-market heatsink like a Scythe Ninja. If I plan on doing little or no overclocking, is there any reason I shouldn't use the stock heatsink?
I am guessing noise might be an issue, but is the stock one really that loud?
I plan on getting the E6600 in a few months, if that matters.
corkyg
Elite Member | Peripherals
27,370
239
Should work OK - it runs cooler than its predecessors.
rudder
19,441
86
It is the same heatsink as on the Pentium D's so it would be safe to say it will cool a conroe cpu.
Slugbait
In this month's issue of MaxPC, they dropped a Zalman on a Conroe...then disabled the fan and encoded an entire DVD. These suckers run really cool, the stock HSF is more than adequate.
