Conroe system
jgigz
413
Looks good as far as I can tell i just glanced over it (im at work). Lucky you though getting a C2D im stealing my bro's old p4 when his C2D gets here cuz im too cheap to buy anythign :p
lamere
479
I have the same video card, awesome card.
Make sure the Zalmen CPU cooler will cool that processer, you might want to give them a call on that, or a local computer store like compUSA or fry's.
The vantec fan card you could probably do without since the video card cooler is encased on the card and blows the heat out the back of the case. I took that off and put on an aftermarket GPU cooler on instead and it works great.
TheSynth
61
Thanks for the tips. Removed the fan card.
I thought I read somewhere that the zalman 9500 would work.
Which GPU cooler did you get and is it an easy task to switch the cooler?
TheSynth
61
I decided to not get the Zalman and go with the stock cooler.
Are you sure the G skill ram will work with the ds3 motherboard? I've been looking around and read about some problems.
buck
12,273
4
If you are still thinking about a gpu cooler, i would go with the accelero2.
