Upgraded to a .11g setup. (DLink Router and PCMCIA Card for my laptop).
Ever since (I had a .11b setup before and no problems) I keep getting a drop connection periodically. It runs fine for a while and then the computer says, "network unavailable"....it soon finds it and drops it....finds it and drop is...the only way to get it back to running normal is to either reboot the computer or take out the PCMCIA card and put it back in to the laptop.
I've tried switching channels, disable 802.11 authentication in XP...still no luck.
I'm about ready to return them both. I would like to try to figure out what is going on before I do.
Thanks!
Thanks!
