Connection Spiking Randomly
Stg-Flame
3,661
603
Internet - UM175AL Alltel Wireless Adapter
My Internet while in-game hovers around 250 ping. As of yesterday, it has been spiking to 700+ after two to three minutes. I ran several speed tests as well as contacted my ISP, who had me run the same tests, and the results were all the same. 1400-1700kbps download speed for the first ten or so tests (give or take a couple) and then it crashes to 100-300kbps download speed for the remainder of my connection until I disconnect and reconnect.
Also, when I start my connection, my sent packets is higher than my received packets for about thirty seconds. I was told by my ISP that this is a sure-fire sign of a security threat, but then again the guy also said that Dell was known for superior anti-virus programs (his exact words).
Any information on this is greatly appreciated.
EDIT: I just ran KL-Detector and it found a few files that are suspicious. The first two are the two main files that it found, the rest after that is the full report.
KL-Detector has found some suspicious files:
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\sessionstore-1.js
F:\Program Files\Valve\Steam\ClientRegistry.blob
Please check; someone might have installed a keylogger on your computer!
And the full report:
Below are some file operations that were done during the monitoring process.
Review them carefully and check for suspicious files.
C:\Windows\ServiceProfiles\NetworkService\ntuser.dat.LOG1
was modified.
C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT
was modified.
was modified.
was modified.
C:\Windows\Temp\TMP000000420C9843AD9F355E8C
was created.
was modified.
was removed.
C:\Windows\Temp
was modified.
C:\Users\Stg\ntuser.dat.LOG1
was modified.
C:\Users\Stg\NTUSER.DAT
was modified.
was modified.
was modified.
C:\Windows\Prefetch\MSPAINT.EXE-76E10B24.pf
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Windows\Temp\TMP00000043A167924A3E1D6A81
was created.
was modified.
was removed.
was modified.
C:\Windows\Temp
was modified.
was modified.
was modified.
was modified.
C:\Windows\Prefetch\NOTEPAD.EXE-D8414F97.pf
was modified.
was modified.
C:\Windows\System32\config\SYSTEM.LOG1
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\parent.lock
was created.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Mozilla Firefox\update.test
was created.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Mozilla Firefox\updates\0
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\pluginreg.dat
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Windows\Prefetch\FIREFOX.EXE-18ACFCFF.pf
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\sessionstore.js
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAP8078.tmp
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\BC59CB6Fd01
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\5E3D90B9d01
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-728x90.swf
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\D817AAA1d01
was created.
was modified.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\DCF39765d01
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was created.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\sessionstore.js.moztmp
was removed.
was modified.
was modified.
was modified.
was modified.
was modified.
was created.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Local\Temp\FAPC729.tmp
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\index.dat
was modified.
C:\Users\Stg\AppData\Roaming\Microsoft\Windows\Cookies\Low\index.dat
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\History\Low\History.IE5\index.dat
was modified.
C:\Windows\Prefetch\RUNDLL32.EXE-70A53FFC.pf
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-WWA_Fall08_freedom_728x90.swf
was modified.
was modified.
C:\Windows\Temp\TMP000000449698709C5D34377C
was created.
was modified.
was removed.
C:\Windows\Temp
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\cookies-1.txt
was modified.
was modified.
was renamed to
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\cookies.txt
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\cookies.txt.moztmp
was removed.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was created.
was modified.
was modified.
was removed.
was modified.
was modified.
was modified.
was modified.
C:\Windows\Prefetch\CALC.EXE-77FDF17F.pf
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was removed.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAP342E.tmp
was created.
was modified.
was modified.
was created.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\sessionstore.jsa
was renamed to
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-QW10625_mmc_hsi_bluelogo_dis_1499_728x90_30K.swf
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\46E8AC7Ed01
was created.
was modified.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam\Steam.lnk
was modified.
was modified.
F:\Program Files\Valve\Steam\stm3813.tmp
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
F:\Program Files\Valve\Steam\stm3BAC.tmp
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Windows\Temp\TMP000000453263708CD9F3C5D9
was created.
was modified.
was removed.
was modified.
C:\Windows\Temp
was modified.
C:\Windows\ModemLogs\ModemLog_PANTECH UM175AL.txt
was modified.
C:\Windows\System32\WDI\LogFiles\WdiContextLog.etl.002
was modified.
was modified.
was modified.
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\Indexer\CiFiles\00010011.wid
was created.
was modified.
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\Indexer\CiFiles\00010011.ci
was modified.
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\Indexer\CiFiles\00010011.dir
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SystemIndex.Ntfy345.gthr
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
F:\Program Files\Valve\Steam\config\SteamAppData.vdf
was modified.
was modified.
F:\Program Files\Valve\Steam\AppUpdateStats.blob
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Windows\System32\wbem\Logs\FrameWork.log
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
was modified.
was modified.
was modified.
C:\Windows\Prefetch\STEAM.EXE-B2DFE6BF.pf
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Microsoft\Windows\Cookies\stg@store.steampowered[2].txt
was created.
C:\Users\Stg\AppData\Roaming\Microsoft\Windows\Cookies\stg@store.steampowered[1].txt
was removed.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\store_steampowered_com[4].htm
was created.
was modified.
was modified.
was created.
was removed.
C:\Windows\Prefetch\SEARCHPROTOCOLHOST.EXE-0CB8CADE.pf
was modified.
was modified.
C:\Windows\Prefetch\SEARCHFILTERHOST.EXE-77482212.pf
was modified.
was modified.
was created.
was modified.
was modified.
was modified.
C:\Windows\Prefetch\STEAMSERVICE.EXE-61749D82.pf
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\capsule_231x87[9].jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\capsule_231x87[10].jpg
was modified.
C:\Windows\System32\config\SOFTWARE.LOG1
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9V9046Q9\capsule_467x181[5].jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9V9046Q9\capsule_231x87[5].jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9V9046Q9\capsule_231x87[6].jpg
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\O19LQ6AF\capsule_sm_120CAC7GH25.jpg
was created.
was modified.
C:\Windows\Prefetch\WMIPRVSE.EXE-1628051C.pf
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\8AA7CCA8d01
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\KH28HPJH\capsule_sm_120CA1DUXHZ.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0GX6POP\capsule_sm_120CAKJSFOT.jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\93T5DEOU\capsule_sm_120CA4AN85P.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3JMI9AX\capsule_sm_120CA0M55PO.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CZFNMA3F\capsule_sm_120CAWL807Q.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\O19LQ6AF\capsule_sm_120CAI3CVOD.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\KH28HPJH\capsule_sm_120CALKCM3B.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0GX6POP\capsule_sm_120CAJP7O99.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\93T5DEOU\capsule_sm_120CANG4DVL.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3JMI9AX\capsule_sm_120CA3H4F79.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CZFNMA3F\capsule_467x181[2].jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CZFNMA3F\capsule_sm_120CAIV7H7G.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\capsule_sm_120CAX1BWDE.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\O19LQ6AF\capsule_sm_120CABXDUE1.jpg
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\KH28HPJH\capsule_sm_120CAUEH8N8.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0GX6POP\capsule_sm_120CAE6FBZO.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\93T5DEOU\capsule_sm_120CAMNYYUC.jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3JMI9AX\capsule_sm_120CAKSSPXM.jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\capsule_sm_120CAPXT6KN.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9V9046Q9\capsule_sm_120CALLRIGF.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\O19LQ6AF\capsule_sm_120CAQ8QLEE.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\KH28HPJH\capsule_sm_120CAGZOASR.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\X0GX6POP\capsule_sm_120CAL9A435.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\93T5DEOU\capsule_sm_120CA5EFIJA.jpg
was created.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAP8B53.tmp
was created.
was removed.
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3JMI9AX\capsule_sm_120CACJ6FH4.jpg
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-CHOW_Bacon_728x90.swf
was created.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\4A86ABFFd01
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\54338141d01
was created.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CZFNMA3F\capsule_467x181[3].jpg
was created.
was modified.
was modified.
was removed.
was created.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z0FM1O0H\capsule_467x181[5].jpg
was created.
was modified.
was modified.
was modified.
was modified.
was renamed to
was removed.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9V9046Q9\capsule_467x181[6].jpg
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAPD761.tmp
was created.
was removed.
was modified.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\O19LQ6AF\capsule_467x181[9].jpg
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\BA142B3Cd01
was created.
was modified.
was modified.
was modified.
was modified.
was modified.
was created.
was removed.
was modified.
was modified.
was modified.
was modified.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\0166083Dd01
was created.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAP152D.tmp
was created.
was removed.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-728x90-1.swf
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Local\Temp\FAP2083.tmp
was created.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-cbs_fb_premium_728x90.swf
was created.
was modified.
was modified.
was created.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Local\Temp\FAP2AE0.tmp
was created.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\F4EA87C9d01
was created.
was modified.
C:\Users\Stg\AppData\Local\Temp\plugtmp-38\plugin-OnTheGo_728x90.swf
was created.
was modified.
was removed.
was modified.
was modified.
was modified.
was removed.
was modified.
was modified.
was modified.
was modified.
was removed.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\bookmarks.html.moztmp
was removed.
was modified.
was modified.
was removed.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\localstore-1.rdf
was created.
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\cert8.db
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\history.dat
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\bookmarks.bak
was modified.
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\bookmarks-1.html
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\_CACHE_001_
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\_CACHE_002_
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\_CACHE_003_
was modified.
was modified.
C:\Users\Stg\AppData\Local\Mozilla\Firefox\Profiles\f6rwb2qb.default\Cache\_CACHE_MAP_
was modified.
C:\Users\Stg\AppData\Roaming\Mozilla\Firefox\Profiles\f6rwb2qb.default\prefs-1.js
was modified.
was modified.
was modified.
was modified.
F:\Program Files\Valve\Steam\config\serverbrowser.vdf
was modified.
was modified.
F:\Program Files\Valve\Steam\config\dialogconfig.vdf
was modified.
was modified.
was modified.
was modified.
F:\Program Files\Valve\Steam\config\shortcuts.vdf
was modified.
was modified.
was modified.
F:\Program Files\Valve\Steam\logs\connection_log.txt
was modified.
F:\Program Files\Valve\Steam\config\masterservers.vdf
was modified.
was modified.
F:\Program Files\Valve\Steam\SteamApps\winui.gcf
was modified.
F:\Program Files\Valve\Steam\Steam.log
was modified.
mechBgon
Oct 31, 1999
30,699
Have you run an antivirus scan using a full antivirus product yet? Here's one, if you need: download the Avira Rescue CD in .ISO format and burn it, then boot your computer from the CD. If you don't have software that burns .ISO to disc, Avira also has a .EXE version that'll burn the disc directly for you.
If the problem persists, you might want to post a HijackThis log, and possibly run Microsoft Network Monitor OneClick and email me the capture file to see if something can be learned from it. PM me if you want to arrange that.
Stg-Flame
3,661
603
Thanks. I will try the Avira since I am using Avast at the moment. Wednesday is my only day off from work and school, so if the problem persists, expect the e-mail late night Tuesday, early morning Wednesday.
