Connection Prob HELP
I have currently installed my old DFI Lan party Ultra D Into my little brothers computer, He was recently using the same mobo but the SLI one. When I installed and turn it on my lan was saying it was connected, but when I went to firefox nothing would come up. I have tried to acces my router and nothing. Even ping or get my gateway ip through cmd prompt. I , dunno what to do, I have tried to reinstall the drivers but still nothing. HELP Thanks
In General you can debug the Network Settings of a computer by following these steps.
Step One. Check the Network parameters in the Computer?s Device Manager. Make sure that the drivers are installed correctly; there is No IRQ conflict, and No Ghost installation. http://www.ezlan.net/faq#ghost
Step Two. Verify Basic network setting in the OS: http://www.ezlan.net/Installing#verify
If the above two Steps indicates that every thing looks good but functionally it does not work.
Step Three. Check (and repair if necessary) the Socket Layers, Winsock, and or refresh the TCP/IP Stack. http://www.ezlan.net/clean#refreshnet
If need to Reinstall; Log to this page it have a lot of links to instructions for Windows Network Installation - http://www.ezlan.net/Installing.html
:sun:
